Введение
You will learn the simple task of removing the blade from the cup. Purchase a replacement here.
Begin by removing the blender from the base. This requires only a twist counterclockwise and a pull up.
Remove the lid and and pull straight up on the blender blade. It will come out easily.
This replacement is quick and easy; therefore if you are having problems with your blade, don't hesitate to check on them.
2 участников успешно повторили данное руководство.
