Введение
In this guide, we are removing the fan from the base of the Ninja.
Выберете то, что вам нужно
Take out the three 15 mm Phillips #1 screws.
Remove the 15mm T10 screw.
Remove the central 15 mm length screw, you must hold the fan in place and use a flat head screw driver, twisting counterclockwise.
Remove the fan from the motor by gently pulling upwards.
Set the fan to the side.
3 участников успешно повторили данное руководство.
