Введение
In this guide we will be removing the blender base and the component housing to get to the fan.
Выберете то, что вам нужно
Remove six screws (12mm long, 6mm head diameter) from bottom of the blender using a Phillips #2 screwdriver
Remove six screws (12mm long, 6mm head diameter) from component housing using Phillips #2 screwdriver.
Using a needle nose pliers, remove nut holding fan in-place. Be careful with fan blades and use a glove or a thick cloth to protect hands.
