Введение
This guide illustrates how to remove the upper rear panel from the Nintendo 2DS to access the battery and other parts of the device.
Выберете то, что вам нужно
Remove the battery from its housing by lifting it up from the side closest to the outside edge.
33 участников успешно повторили данное руководство.
4 Комментариев
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
This didnt help my problem
maybe its because you did not plug the battery correctly matthew
or maybe its just not working ludovic 🫡
