Введение
This guide will show you how to replace the volume button of your Nintendo 2DS. The volume button may not break often but if you find yourself with a button that is stuck in place or you're unable to control the level of volume, this guide may help.
Before beginning this repair, turn off the device.
Выберете то, что вам нужно
Turn the 2DS over so that the backside is facing upwards.
Identify the two Phillips #00 screws on the upper rear panel.
Loosen the two screws on the upper back panel using a Phillips #00 screwdriver.
Use a spudger to pry the upper back panel off, starting at the indent at the center top of the panel.
Use a spudger and work your way around the perimeter to release the clips and then lift the panel off.
Use your finger or a spudger to lift and pull the battery outwards from the side closest to the outer edge.
Pull the stylus out from the middle of the left edge of the device.
Use a Phillips #00 screwdriver to remove ten 2.0 mm screws from the back panel.
Use a spudger to pry the back case off by working around the perimeter of the device, starting from the bottom of the 2DS.
Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the camera cable.
Use your spudger to gently slide the cable out of the connector.
Remove the back case.
