Nintendo 3DS 2015 Battery Replacement
Выберете то, что вам нужно
  1. Nintendo 3DS 2015 Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Unscrew the two 3mm Phillips #0 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Battery Replacement: шаг 2, изображение 1 из 2 Nintendo 3DS 2015 Battery Replacement: шаг 2, изображение 2 из 2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Battery Replacement: шаг 3, изображение 1 из 3 Nintendo 3DS 2015 Battery Replacement: шаг 3, изображение 2 из 3 Nintendo 3DS 2015 Battery Replacement: шаг 3, изображение 3 из 3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
Заключение
6 участников успешно повторили данное руководство.
Tyler Starr
Участник с: 10/06/16
1 509 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 4-6, Livingston Fall 2016 Участник Cal Poly, Team 4-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G6
4 членов
Автор 35 руководств
4 Комментариев
The link to the Nintendo store to buy a battery no longer functions.
David Clarke - Ответить
My console has been off and without a battery for months now and I haven't been able to get a replacement battery until very recently, I replaced it just now and the orange led lights on (albeit for a short time) but the console won't turn on. The blue led lights up briefly then goes out again and the console remains off. Could it be something wrong with the console itself rather than the battery? Edit: Should I just leave it plugged in for a while even if the orange led doesn't stay on?
Leon J - Ответить
I solved it by cleaning the contacts, reseating the battery and removing the microSD card. The SD card can then be put back in later
Leon J -
How's the battery life on it so far? I know you just posted 2 days ago, but I was just curious.
Will Reds -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 47
За последние 30 дней: 250
За всё время: 5,244
