Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Запчасти
Детали не указаны.
  1. Этот шаг не переведен. Помогите перевести
    Unscrew the four Phillips #00 screws along the top of the back cover.
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Этот шаг не переведен. Помогите перевести
    Hold the device in one hand and turn it over. Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
Финишная черта
12 участников успешно повторили данное руководство.
David Hodson
Участник с: 13.04.2010
140 203 Репутация
Автор 127 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 20
За последние 30 дней: 104
За всё время: 13,092
