Введение
The 3DS charging port is soldered to the motherboard. To remove it, click here and follow this guide to remove the motherboard, and then use your soldering skills to remove and replace the charging port.
Note: steps 7-8 are for replacing the charging port piece with one from another 3DS system. You can order a new piece from amazon and just use it instead.
The guide you are currently viewing has been archived until the procedure can be updated. Following this guide may damage your device.
Выберете то, что вам нужно
Take out the 4 screws on the back of the system using a Phillips #00 Screwdriver.
You will see small black screws in nine different holes. make sure you use the right screwdriver and remove them. Also remove the one silver screw that holds the game cartridge slot.
After you have unscrewed all of the screws. Carefully remove the back with a spudger.
After you pull it open, you will see the motherboard. Locate the charging port. It should look like this.
If you got a charger port for a 3DS, you can skip this step. From another 3DS, desolder the charger port.
4 участников успешно повторили данное руководство.
2 Комментариев
you solder with everything connected to the mobo??
Everything but the battery. I actually took mine out of the case before doing anything. But I kept it connected to the screen. I would not do this without a very fine soldering gun.
