Введение
Circle pad joystick prerequisite.
Запчасти
Детали не указаны.
Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
Lift the Circle Pad joystick off the motherboard.
Use a spudger or screwdriver to lift the pads up and remove them from the device.
