Введение
This guide is a prerequisite to removing the upper LCD, speakers, Wi-Fi antenna, and cameras.
Инструменты
Запчасти
Детали не указаны.
Remove the 3D adjustment switch from the front display bezel.
Insert a metal probe into the space above the ABXY buttons with the point touching the metal hinge.
Push the hinge towards the center of the upper case. This will require a fair amount of force.
Slowly pull the upper display assembly away from the upper case.
Make sure that the various ribbon cables are being fed through the slit in the upper case.
Separate the upper display assembly from the upper case.
