Введение
Removing the battery is essential to the removal of other components on the Nintendo 3DS XL. Please remember to have the device powered off when following this guide.
  1. Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  2. Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
    My experience indicates that a JIS #1 is more appropriate here.
    John Menden - Ответить
  3. Once the screws are loosened, pry open the back cover.
    • Once the screws are loosened, pry open the back cover.
  4. The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a pointed tool.
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a pointed tool.
    Also you should remove any SD card at this point
    James Grant - Ответить
Заключение
13 участников успешно повторили данное руководство.
Kobbe Farwick
Участник с: 01.04.2015
1 631 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 24-4, Lancaster Spring 2015 Участник Cal Poly, Team 24-4, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G4
4 членов
Автор 17 руководств
Комментариев: 3
Bonjour,
Tout d’abord merci pour ces explications claires et précises. Toutefois, je me demandais s’il y avait un endroit où l’on peut trouver une batterie officielle Nintendo ? Après quelque recherches je n’ai malheureusement rien trouvé (et comme la console est vieillissante…)?
Nicolas BARET - Ответить
Bonjour Nicolas Si vous voulez une pièce de nintendo, vous devez être en amérique ou au canada car nintendo ne vend des pièces que dans ces pays, je peux vous donner le site Web pour les états-unis et le canada si vous le souhaitez.
Nelson Berrios -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 36
За последние 30 дней: 134
За всё время: 5,397
