Введение
Does your Rumble Pak no longer vibrate? Learn how to check for corrosion and replace the batteries in your Rumble Pak to continue enjoying the ultimate gaming experience.
Выберете то, что вам нужно
Remove the Rumble Pak from the controller by pressing the release button and pulling the Rumble Pak out.
Remove the battery cover from the Rumble Pak by pressing the tab and pulling the cover up.
Press each battery toward the spring, then pull toward you to remove the batteries from the Rumble Pak.
Check for corrosion around the springs and the flat plate where the batteries touch.
Use a flat head screwdriver to chisel away the corrosion, and use a Q-tip to wipe it clean.
