Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the expansion pack cover by pushing in the tab and pulling out.
Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
Remove the metal plate indicated in the example by sliding it back and then lifting it up.
Remove the two screws indicated in the example using the smaller Phillips screwdriver.
Remove the screw to the right of the LED light using the larger Phillips screwdriver.
Remove the small metal bracket from the back of the expansion pack slot.
Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
Remove the small metal bracket behind the expansion slot using the spudger.
Remove the seven screws indicated in the example using the larger Phillips screwdriver.
Lift off and remove the metal plate as indicated in the example.
Remove the four screws indicated using the #1 Phillips screwdriver.
23 участников успешно повторили данное руководство.
