Введение
This fix is necessary for the owners of N64 controllers when the joystick becomes too loose over time. If the joystick of a controller is loose, game play becomes difficult. Conditions for this fix include: a flat surface, plenty of light, and a method for keeping track of individual components of the controller. Practice caution when using the knife in this fix.
Выберете то, что вам нужно
Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
Remove the back panel from the controller.
Remove the screws (4.8 mm Phillips head) from the back of the white joystick box.
Remove the back panel of the white joystick box.
Remove the screw (4.8 mm Philips head) from the back of the joystick box.
Remove the joystick box from the controller.
Pinch off a small piece of epoxy and knead it in your hand until a uniform color is reached.
Press the epoxy into the center of the bowl with your finger and add a drop of water into the bowl.
Place a marble into the bowl and use a push-twist motion to form the epoxy into the shape of the bowl.
Cut the edges of the excess epoxy with the exacto knife.
Repeat steps 8 and 9 until no excess epoxy is left.
The fix is now complete. Move the joystick to test the stiffness. If the joystick is still very loose, you may need to add more epoxy. If the joystick is too stiff, you may need to remove excess epoxy.
13 участников успешно повторили данное руководство.
7 Комментариев
N64 Joystick Permanent Fix & Refurbish New Parts Cheap
Sadly, it is out of stock too frequently. I’d prefer fixing rather than replacing.
What is the epoxy substance called exactly? I tried searching online but results all come back for JB-Weld coldweld bonding products.
It took me a while too to find what they're using. I'm pretty sure it's Epoxy Putty, it's used to patch and seal holes.
JB-Weld does seem to sell most of what's available to buy, maybe their PlasticWeld one would be most appropriate.
