Введение
This guide will show how to replace the Nintendo 64 motherboard.
Выберете то, что вам нужно
Remove the expansion pack cover by pushing in the tab and pulling out.
Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
I’m not entirely certain if it's a common difference, but my nintendo 64 doesn’t have fourteen screws, but rather, 8 screws, and instead of 3 heat sinks, it only has the one separate heat sink on the chip close to the memory expansion pack. additionally, aside from the 6 screws closest to the expansion pack, the two other screws are held on by nuts under the metal piece.
Remove the metal plate indicated in the example by sliding it back and then lifting it up.
Remove the two screws indicated in the example using the smaller Phillips screwdriver.
Remove the screw to the right of the LED light using the larger Phillips screwdriver.
Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
I have noticed this is not in Australian Pal versions of the N64.
at First i thought i was missing a bit on my N64 and now have looked a second one and its also not there.
Remove the seven screws indicated in the example using the larger Phillips screwdriver.
Remove the four screws indicated using the #1 Phillips screwdriver.
36 участников успешно повторили данное руководство.
