Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will show how to replace the Nintendo 64 motherboard.
Выберете то, что вам нужно
Remove the expansion pack cover by pushing in the tab and pulling out.
Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
Remove the metal plate indicated in the example by sliding it back and then lifting it up.
Remove the two screws indicated in the example using the smaller Phillips screwdriver.
Remove the screw to the right of the LED light using the larger Phillips screwdriver.
Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
Remove the seven screws indicated in the example using the larger Phillips screwdriver.
Remove the four screws indicated using the #1 Phillips screwdriver.
36 участников успешно повторили данное руководство.
