Введение
Prerequisite-only guide to disconnect the Nintendo DS Lite battery before further disassembly.
  1. Place your device upside down and locate the battery compartment.
    • Place your device upside down and locate the battery compartment.
    • Find the phillips head screw securing the battery cover in the bottom right hand corner of the device.
    • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
    • Use only a phillips screwdriver to remove screw.
  2. Slowly remove the battery cover with the iFixit opening tool.
    • Slowly remove the battery cover with the iFixit opening tool.
    • Make sure to remove the cover carefully to keep from losing phillips screw in the cover. It will be needed for reassembly.
  3. Use the iFixit opening tool to carefully pry the battery out of the case. After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • Use the iFixit opening tool to carefully pry the battery out of the case.
    • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
Заключение
To replace battery and reassemble your device, follow these instructions in reverse.
2 участников успешно повторили данное руководство.
Brittany K
Участник с: 21.01.2010
1 395 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 16-30, Maness Winter 2010 Участник Cal Poly, Team 16-30, Maness Winter 2010
CPSU-MANESS-W10S16G30
4 членов
Автор 16 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 5,600
