Введение
Prerequisite-only guide to disconnect the Nintendo DS Lite battery before further disassembly.
Выберете то, что вам нужно
Place your device upside down and locate the battery compartment.
Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
Use the iFixit opening tool to carefully pry the battery out of the case.
After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
To replace battery and reassemble your device, follow these instructions in reverse.
2 участников успешно повторили данное руководство.
