Nintendo DS Lite Battery Replacement
Выберете то, что вам нужно
  1. Nintendo DS Lite Battery Replacement, Battery: шаг 1, изображение 1 из 2 Nintendo DS Lite Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
    Спросите у FixBot
    Добавить комментарий
  2. Nintendo DS Lite Battery Replacement: шаг 2, изображение 1 из 1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
    Спросите у FixBot
Заключение
52 человек успешно провели ремонт по этому руководству.
Matthew Newsom
Участник с: 01/05/10
42 796 Репутация
Автор 67 руководств
6 Комментарии к руководству
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - Ответить Поделиться
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - Ответить Поделиться
Thanks but will a dsi battery work
Zach - Ответить Поделиться
While a very late reply, someone else may find this useful.
In short, no. Not at all. The DS Lite Battery I own (Original) Is listed as
USG-003
3.7v
1000 mAH
3.7 Wh
Where as the DSi battery I own (Again, an original straight from my console) is listed as:
TWL-003
3.7v
840 mAH
3.1 Wh
While the same voltage and a slight difference in capacity, the DSi Battery is slightly longer and slimmer in width to the DS/DS Lite Battery and you will need to find a battery suited for the DS/DS Lite you're using. Many places will sell these batteries but do your research as not all of these are created equal.
kaelowynlee - Ответить Поделиться
My battery cover won’t come off.
Jake - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 14
За последние 7 дней: 188
За последние 30 дней: 821
За всё время: 76,190
