Nintendo DS Lite Battery Replacement
Выберете то, что вам нужно
  1. Nintendo DS Lite Battery Replacement, Battery: шаг 1, изображение 1 из 2 Nintendo DS Lite Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
    A Phillips #000 (PH000) seems to give a more secure fit (no slipping) than the stated Phillips #00.
    Ritchie - Ответить
    This will be good for mods
    Matthew Bevins - Ответить
    I'm having a problem getting the screw to unscrew. I have the right Phillips ( it was included with all the stuff I got this) Any tips. it doesn't look like the screw is spinning but i haven't played my Nintendo DS Lite for 3 years.
    whittlegirls - Ответить
    bonjour j’ai une petite question pour vous fais trés longtemps que j’ai pas utiliser mon nintendo ds lite et quand je le branche il allume 1 fois orange après il s’enteint même s’il est brancher ça veux tu dire qu’il faut que je change de batterie ? Merci
    Marie-Julie Richer - Ответить
    Soit un changement de batterie, soit la carte-mère a peut-être un court-circuit :/
    Polaris -
  2. Nintendo DS Lite Battery Replacement: шаг 2, изображение 1 из 1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
Заключение
46 участников успешно повторили данное руководство.
Matthew Newsom
Участник с: 01/05/10
38 915 Репутация
Автор 67 руководств
5 Комментариев
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - Ответить
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - Ответить
Thanks but will a dsi battery work
Zach - Ответить
My battery cover won’t come off.
Jake - Ответить
Flip the console upside down and it will but don’t pull it will break hold it close to the console then slide it back
dead -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 17
За последние 7 дней: 126
За последние 30 дней: 626
За всё время: 47,708
