Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Has your DS Lite battery stopped providing the game time you deserve? Replace the battery to free yourself from the wall charger.
Выберете то, что вам нужно
Unscrew the Phillips screw securing the battery cover to the lower case.
Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
Remove the battery from the DS Lite.
46 участников успешно повторили данное руководство.
5 Комментариев
Can you describe the type of screw and captive washer ?
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
