Введение
This guide will explain how to replace the shoulder buttons on a DS Lite if they are sticking or not working properly.
The tools you’ll need for this task are:
  • Spudger or other flat tool
  • Screwdrivers
    • Phillips
    • Tri-wing
Запчасти
Детали не указаны.
  1. Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
    • Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
  2. Use a spudger to pry out the battery.
    • Use a spudger to pry out the battery.
    • Pry off the rubber feet.
    • Remove the seven screws securing the lower case:
    • Three tri-wing screws
    • One Phillips screw
    • Two gold Phillips screws
    • One black tri-wing screw
  3. Carefully pry the bottom cover off.
    • Carefully pry the bottom cover off.
    • Remove the shoulder buttons by pulling out the metal pegs that secure them to DS.
    • The triggers are held in by tiny metal pegs and springs. Keep track of each piece.
  4. You can now access the micro-button component and replace or repair anything as needed. You can now access the micro-button component and replace or repair anything as needed. You can now access the micro-button component and replace or repair anything as needed.
    • You can now access the micro-button component and replace or repair anything as needed.
Заключение
To reassemble your device, follow the steps in reverse order after making your repair.
2 участников успешно повторили данное руководство.
Francisco Varela
Участник с: 01.02.2019
163 Репутация
1 руководство автора
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 21
За последние 30 дней: 87
За всё время: 728
