Nintendo DS Lite Wi-Fi Board Replacement
Выберете то, что вам нужно
  1. Nintendo DS Lite Wi-Fi Board Replacement, Battery: шаг 1, изображение 1 из 2 Nintendo DS Lite Wi-Fi Board Replacement, Battery: шаг 1, изображение 2 из 2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Nintendo DS Lite Wi-Fi Board Replacement: шаг 2, изображение 1 из 1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
  3. Nintendo DS Lite Wi-Fi Board Replacement, Lower Case: шаг 3, изображение 1 из 2 Nintendo DS Lite Wi-Fi Board Replacement, Lower Case: шаг 3, изображение 2 из 2
    • Use the tip of a spudger to pry both rubber feet off the DS Lite.
  4. Nintendo DS Lite Wi-Fi Board Replacement: шаг 4, изображение 1 из 1
    • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-Wing screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-Wing screws
  5. Nintendo DS Lite Wi-Fi Board Replacement: шаг 5, изображение 1 из 3 Nintendo DS Lite Wi-Fi Board Replacement: шаг 5, изображение 2 из 3 Nintendo DS Lite Wi-Fi Board Replacement: шаг 5, изображение 3 из 3
    • Remove the cover from the Game Pak slot before continuing.
    • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
    • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
    • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
  6. Nintendo DS Lite Wi-Fi Board Replacement: шаг 6, изображение 1 из 1
    • Lift the lower case away from the rest of the DS Lite.
    • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
    • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
  7. Nintendo DS Lite Wi-Fi Board Replacement, Trigger Buttons: шаг 7, изображение 1 из 2 Nintendo DS Lite Wi-Fi Board Replacement, Trigger Buttons: шаг 7, изображение 2 из 2
    • Lift both trigger buttons out of the DS Lite.
    • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
    • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
  8. Nintendo DS Lite Wi-Fi Board Replacement, Wi-Fi Board: шаг 8, изображение 1 из 1
    • Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  9. Nintendo DS Lite Wi-Fi Board Replacement: шаг 9, изображение 1 из 1
    • Use the flat edge of a spudger to pry the Wi-Fi board connector straight up from its socket on the motherboard.
  10. Nintendo DS Lite Wi-Fi Board Replacement: шаг 10, изображение 1 из 1
    • Use the flat edge of a spudger to separate the right edge of the Wi-Fi board from the motherboard.
    • The Wi-Fi board is secured to the motherboard with a layer of adhesive.
    • Remove the Wi-Fi board from the DS Lite.
Заключение
8 участников успешно повторили данное руководство.
Matthew Newsom
Участник с: 01/05/10
39 500 Репутация
Автор 67 руководств
3 Комментариев
So I came across a "Prison edition" DSLite out of the Kentucky DOC It I was told that the wifi card was disabled but I take it apart and see that it is still there pluged in and everything you don't happen to know how to turn it back on do you it is a gift for my little brother and would like the WiFi to work.
Vincent - Ответить
Question anyone knows what the pin layout of the board
Aaron Darren - Ответить
Merhaba Nintendo Ds lite da wifi kartı bozuldugunda ekran açılmaması normal mi ds lite a güç geliyor ışıklar yanıyor ama ekran gelmiyor
Boş - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 37
За последние 30 дней: 148
За всё время: 15,702
