Nintendo DSI Battery Replacement
Выберете то, что вам нужно
  1. Nintendo DSI Battery Replacement, Setup and Parts: шаг 1, изображение 1 из 1
    • To begin the battery replacement, have all your tools and parts nearby and ready to go.
    • Nintendo DSI
    • #00 2.0mm Phillips Head Screwdriver OR Precision Screwdriver Kit
    • Spudger or Prying Tool
    • Nintendo DSI Battery
  2. Nintendo DSI Battery Replacement, Accessing the battery compartment: шаг 2, изображение 1 из 3 Nintendo DSI Battery Replacement, Accessing the battery compartment: шаг 2, изображение 2 из 3 Nintendo DSI Battery Replacement, Accessing the battery compartment: шаг 2, изображение 3 из 3
    • On the backside of the DSI, you'll notice a plastic panel with two screws off to the side. Unscrew both screws using a #00 Phillips head screwdriver or an appropriately sized screwdriver bit.
    • Unscrew both screws using a #00 Phillips head screwdriver or an appropriately sized screwdriver bit. The screws will stay with the panel during removal.
    • Lift the plastic panel up and away from the DSI. If the panel stays in place after unscrewing, hold the DSI upsidedown and gently tap the device. This should free the panel.
  3. Nintendo DSI Battery Replacement, Removing and Replacing the battery pack: шаг 3, изображение 1 из 3 Nintendo DSI Battery Replacement, Removing and Replacing the battery pack: шаг 3, изображение 2 из 3 Nintendo DSI Battery Replacement, Removing and Replacing the battery pack: шаг 3, изображение 3 из 3
    • Once you've removed the plastic panel, you'll have full access to the battery pack.
    • Using the spudger/prytool or gently tapping the DSI, lift and remove the battery upwards and away from the device.
    • [IMPORTANT] when installing the replacement battery pack, make sure to line up the positive and negative terminals on the battery to those on the battery compartment on the DSI
  4. Nintendo DSI Battery Replacement, Finishing up: шаг 4, изображение 1 из 1
    • Once you've reinstalled/replaced the battery pack. Reinstall the plastic panel, making sure to line up the plastic hinges on the side adjacent to the screws.
    • Drop the panel into place and retighten both of the screws.
Заключение
Congratulations! You just replaced your Nintendo DSi's battery!
4 участников успешно повторили данное руководство.
Edrick Tong
Участник с: 01/26/22
217 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 17
За последние 30 дней: 78
За всё время: 1,679
