Введение
Use this guide to replace the microphone in your Nintendo DSi
Выберете то, что вам нужно
Unscrew the two Phillips screws securing the battery cover to the lower case.
Grasp the battery cover and lift it out of the lower case.
Using a spudger tool (or your fingernail), lift up the battery from the top.
Grasp the battery and remove it from the DSi.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
Remove the following screws securing the lower case to the body of the DSi:
Six 5.2 mm Phillips #00 screws.
One 2.7 mm Phillips #00 screw.
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Carefully lift the lower casing from its bottom edge.
Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
Once the cable is completely removed, then you may take off the entire outer casing.
Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
Lower touchscreen cable
Lower LCD cable
Power board cable
After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
Remove the following four Phillips screws securing the motherboard to the DSi framework.
Three longer screws.
One short screw.
Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
Remove the motherboard from the DSi.
Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
Lift the lower LCD assembly out of the DSi.
Use a pushpin to remove the four plastic screw covers (highlighted in red) on the front bezel.
Using two hands, gently slide the rear bezel upwards.
Lift the rear bezel straight up out of the DSi.
De-route the Wi-Fi and microphone cables from the slot molded into the bottom front bezel.
Use the tip of a spudger to gently lift the microphone out of its housing in the top front bezel.
De-route the microphone cable through the hinge and remove it from the DSi.
Еще один человек закончил это руководство.
2 Комментариев
Love the guide! If your mic still doesn’t work look into the headphone/mic jack and see if the two pins are pulled down inside. If they are stuck up then the mic will default to the jack mic input even if there’s nothing in the socket. I pulled mine down with the Ifixit tweezers and this fixed my mic problems.
Hey this worked for me thanks! I wonder how you found out lol
