Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will walk you through replacing your DSi's touchscreen.
Выберете то, что вам нужно
Unscrew the two Phillips screws securing the battery cover to the lower case.
Grasp the battery cover and lift it out of the lower case.
Using a spudger tool (or your fingernail), lift up the battery from the top.
Grasp the battery and remove it from the DSi.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
Remove the following screws securing the lower case to the body of the DSi:
Six 5.2 mm Phillips #00 screws.
One 2.7 mm Phillips #00 screw.
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Carefully lift the lower casing from its bottom edge.
Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
Once the cable is completely removed, then you may take off the entire outer casing.
Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
Lower touchscreen cable
Lower LCD cable
Power board cable
After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
Remove the following four Phillips screws securing the motherboard to the DSi framework.
Three longer screws.
One short screw.
Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
Remove the motherboard from the DSi.
Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
Lift the lower LCD assembly out of the DSi.
Insert the edge of a plastic opening tool between the lower touchscreen and the lower LCD.
Carefully run the edge of the opening tool along the perimeter of the touchscreen to detach it from the lower LCD.
Remove the touchscreen from the lower LCD.
17 участников успешно повторили данное руководство.
5 Комментариев
As always an excellent well documented and easily explained guide. My DSi touch screen now calibrates and works perfectly. Thank you so much for your excellent site.
I have replaced the digitalizer but still the touch screen is not working, I've already make sure that all the ribbon cables are correctly connected, what could be the problem? The motherboard? I'm running out of options, any help will be really appreciated
