Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Replace both of your DSi XL's cameras and get back to editing bug eyes onto pictures of your little sister.
  1. Remove the two Phillips screws securing the battery cover to the back of the handheld console. Lift the battery cover off the back of the DSi XL.
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Lift the battery from the DSi XL.
    • Lift the battery from the DSi XL.
  3. Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin.
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Turn the DSi XL over, and open the display. Insert a spudger between the upper and lower case at the bottom left corner of the DSi. Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Close the display and turn the DSi XL over. Lift the lower case from the front edge.
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Using a spudger, pry the SD card/right shoulder button connector off its socket. Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Lift the Wi-Fi board up off its socket on the motherboard. Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  9. Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
  10. Use a spudger to pry the microphone cable off the motherboard.
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
  11. Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector. Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  12. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  13. Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector. With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  14. Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector. With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  15. Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector. With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  16. Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable. With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  17. Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  18. Remove the screws securing the motherboard to the upper case:
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
  19. Deroute the microphone and antenna cables through the slot in the motherboard.
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  20. Rotate the motherboard off the lower case. The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  21. Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector. With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
  22. With the console still upside-down, open the DSi XL slightly. Push the lower display away from the upper case.
    • With the console still upside-down, open the DSi XL slightly.
    • Push the lower display away from the upper case.
    • Remove the lower display from the DSi XL.
  23. Turn the DSi XL over and open the display. When re-assembling the device, be sure to re-install the ABXY and Start/Select buttons, as they are likely to fall out once the handheld console is turned over. Use a pushpin to remove the four plastic screw covers on the front bezel.
    • Turn the DSi XL over and open the display.
    • When re-assembling the device, be sure to re-install the ABXY and Start/Select buttons, as they are likely to fall out once the handheld console is turned over.
    • Use a pushpin to remove the four plastic screw covers on the front bezel.
  24. Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
    • Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
  25. Using two hands, gently slide the rear bezel upwards. The rear bezel will move only about 2 mm.
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  26. Insert a spudger into the gap between the front and rear bezel. Rotate the spudger away from the DSi XL, prying the two bezels apart.
    • Insert a spudger into the gap between the front and rear bezel.
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  27. In the same manner as described above, continue prying along the top edge of the front and rear bezels. In the same manner as described above, continue prying along the top edge of the front and rear bezels.
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  28. Separate the rear bezel from the front bezel.
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  29. Using the flat end of a spudger, pry the rear camera off the rear bezel.
    • Using the flat end of a spudger, pry the rear camera off the rear bezel.
    • Remove the rear bezel.
  30. Remove the Phillips screw holding the metal securing bracket in place. Lift the metal bracket off the camera.
    • Remove the Phillips screw holding the metal securing bracket in place.
    • Lift the metal bracket off the camera.
    • The bracket cannot be completely removed yet, because is attached to the upper display data cable.
  31. Lift the camera out of its seat on the front bezel.
    • Lift the camera out of its seat on the front bezel.
  32. Grab the LCD and camera cable with one hand, and slowly feed the camera cable and data display cable through the right hinge connecting the upper case and front bezel. Use your free hand to guide the ends of the cables through the right hinge. Be careful when feeding the thin ribbon cable through the hole; it will tear easily.
    • Grab the LCD and camera cable with one hand, and slowly feed the camera cable and data display cable through the right hinge connecting the upper case and front bezel.
    • Use your free hand to guide the ends of the cables through the right hinge.
    • Be careful when feeding the thin ribbon cable through the hole; it will tear easily.
  33. When feeding the camera and upper LCD cables through the right hinge, it is helpful to wrap the cables together with a piece of tape. Be sure to wrap the cables tight enough to get through the hole, but not so tight as to damage or bend the the connections.
    • When feeding the camera and upper LCD cables through the right hinge, it is helpful to wrap the cables together with a piece of tape.
    • Be sure to wrap the cables tight enough to get through the hole, but not so tight as to damage or bend the the connections.
  34. Remove the camera ribbon from the DSi XL.
    • Remove the camera ribbon from the DSi XL.
Заключение
David Hodson
Участник с: 13.04.2010
137 946 Репутация
Автор 127 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,025
