Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Lift the Wi-Fi board up off its socket on the motherboard.
Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
Use a spudger to pry the microphone cable off the motherboard.
Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
Remove the screws securing the motherboard to the upper case:
A single 2.5 mm silver Phillips screw
Four 3.7 mm black Phillips screws
Deroute the microphone and antenna cables through the slot in the motherboard.
Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
With the console still upside-down, open the DSi XL slightly.
Push the lower display away from the upper case.
Remove the lower display from the DSi XL.
Turn the DSi XL over and open the display.
Use a pushpin to remove the four plastic screw covers on the front bezel.
Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
Insert a spudger into the gap between the front and rear bezel.
Rotate the spudger away from the DSi XL, prying the two bezels apart.
In the same manner as described above, continue prying along the top edge of the front and rear bezels.
Using the flat end of a spudger, pry the rear camera off the rear bezel.
Remove the rear bezel.
Remove the Phillips screw holding the metal securing bracket in place.
Lift the metal bracket off the camera.
Lift the Wi-Fi antenna off the front display bezel.
De-route the Wi-Fi antenna cable from its grooves at the bottom of the front display bezel.
Pull the Wi-Fi antenna cable through the right hinge connecting the front bezel and upper case.
Use the pointed end of a spudger to guide the connector at the end of the Wi-Fi antenna cable through the hinge.
Using a pair of tweezers, pull the microphone out of its housing in the front bezel.
De-route the microphone cable, and pull it through the right hinge.
Using the flat end of a spudger, pry the left speaker out of its socket on the front bezel.
De-route the speaker cable along the top edge of the screen.
In the same manner described above, remove the right speaker from its socket on the front bezel.
Place both speakers on the back of the upper LCD.
Remove the seven 2.5 mm silver screws securing the power board to the upper case.
Lift the power board up off the upper case.
Peel the rubber button pads off the backside of the D-pad and power button.
Push the D-pad up through its housing in the upper case. Remove the D-pad.
In the same way, remove the power button from the upper case.
Using a pair of tweezers, remove the LED diffuser bracket and the LED diffuser from the upper case of the DSi XL.
Place the tip of a spudger in the LED diffuser compartment, on the face of the clutch hinge.
Push the clutch hinge to the left.
Lift the left side of the front bezel away from the upper case.
Pull the front bezel to the left, separating the front bezel from the upper case.
Grasp the camera and upper LCD ribbon cables between your thumb and forefinger, pulling them out of the upper case slightly, slide them down through the slit in the upper case.
Rotate the front bezel assembly clockwise so that the ends of the camera and LCD cables slide sideways through the slit in the front bezel.
Carefully coil the two ribbon cables together, so that the connectors are on the inside of the spool.
Holding the upper LCD and the cameras together, pull the cables through the hinge in the front bezel.
Uncoil the ribbon cables.
Pull the hollow hinge pin out of the right side of the front bezel.
Push the clutch hinge on the left side of the front bezel through its mount bracket.
Remove the clutch hinge.
3 участников успешно повторили данное руководство.
