Введение
Get the power flowing through your DSi XL by replacing the power board.
  1. Remove the two Phillips screws securing the battery cover to the back of the handheld console. Lift the battery cover off the back of the DSi XL.
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Lift the battery from the DSi XL.
    • Lift the battery from the DSi XL.
  3. Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin.
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Turn the DSi XL over, and open the display. Insert a spudger between the upper and lower case at the bottom left corner of the DSi. Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Close the display and turn the DSi XL over. Lift the lower case from the front edge.
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Using a spudger, pry the SD card/right shoulder button connector off its socket. Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable. With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
    • With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
  9. Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
    • Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
    • Use caution, as the wires are very fragile and could come out of the connector if pulled on too hard.
  10. Remove the seven 2.5 mm silver screws securing the power board to the upper case. Lift the power board off the upper case.
    • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
    • Lift the power board off the upper case.
Заключение
6 участников успешно повторили данное руководство.
Brett Hartt
Участник с: 12.04.2010
122 091 Репутация
Автор 143 руководств
Команда
iFixit Участник iFixit
Community
140 членов
Автор 17 045 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 31
За всё время: 15,156
