Введение
Be the envy of onlooking gamers with a shiny new rear bezel on your DSi XL.
  1. Use a push pin to remove the four plastic screw covers on the front bezel. Use a push pin to remove the four plastic screw covers on the front bezel. Use a push pin to remove the four plastic screw covers on the front bezel.
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  2. Remove four Phillips screws securing the front bezel to the rear bezel.
    • Remove four Phillips screws securing the front bezel to the rear bezel.
  3. Using two hands, gently slide the rear bezel upwards. The rear bezel will move only about 2 mm.
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  4. Insert a spudger into the gap between the front and rear bezel Rotate the spudger away from the DSi XL, prying the two bezels apart.
    • Insert a spudger into the gap between the front and rear bezel
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  5. In the same manner as described above, continue prying along the top edge of the front and rear bezels.
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  6. Separate the rear bezel from the front bezel.
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  7. Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Remove the rear bezel.
Заключение
2 участников успешно повторили данное руководство.
Matthew Newsom
Участник с: 05.01.2010
36 656 Репутация
Автор 67 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 4,570
