Введение
Replace your DSi XL's speakers so you can hear Mario yell "Mamma mia" as clear as ever.
Выберете то, что вам нужно
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Use a push pin to remove the four plastic screw covers on the front bezel.
Insert a spudger into the gap between the front and rear bezel
Rotate the spudger away from the DSi XL, prying the two bezels apart.
In the same manner as described above, continue prying along the top edge of the front and rear bezels.
Use the flat end of a spudger to pry the rear camera off the rear bezel.
Remove the rear bezel.
Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
Open the display slightly, and lift the LCD out of the front bezel.
Lay the LCD down next to the DSi XL.
Desolder the two solder joints to separate the speakers from the LCD.
Right Speaker
Left Speaker
3 участников успешно повторили данное руководство.
3 Комментариев
In my case, it turned out there was nothing wrong with my speaker… one of the wires that feeds around the screen was bad.
is there anyway of adding two more speaker?
rust/white powder built up on a screw and can’t unscrew it
Eco - Ответить
