Nintendo Game Boy Advance SP Brightness Switch Replacement
Выберете то, что вам нужно
  1. Nintendo Game Boy Advance SP Brightness Switch Replacement, Battery: шаг 1, изображение 1 из 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
    Quel est le nom du vis svp je l'ai perdu et j'ai pas la référence
    la chaîne de Samarium - Ответить
    Bonjour @lachainede96340 D'après les instructions du tutoriel, il s'agit d'une vis Phillips (ou cruciforme) #00 de 4 mm de long. Ces mesures devraient suffire pour trouver une vis de remplacement dans votre stock de vis ou en magasin le cas échéant.
    Claire Miesch -
  2. Nintendo Game Boy Advance SP Brightness Switch Replacement: шаг 2, изображение 1 из 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Brightness Switch Replacement: шаг 3, изображение 1 из 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Brightness Switch Replacement, Back Cover: шаг 4, изображение 1 из 2 Nintendo Game Boy Advance SP Brightness Switch Replacement, Back Cover: шаг 4, изображение 2 из 2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Brightness Switch Replacement: шаг 5, изображение 1 из 1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Brightness Switch Replacement, Motherboard: шаг 6, изображение 1 из 1
    • Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
  7. Nintendo Game Boy Advance SP Brightness Switch Replacement: шаг 7, изображение 1 из 1
    • Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
    • Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
    My Game Boy Advance SP has a problem where it won’t charge the device. The Game Boy is plugged in but the charge light does not go on. How may I turn it back on? What, inside the system, needs to be fixed? Is it one of the cables behind the charging socket inside the Game Boy?
    Connor Hutton - Ответить
  8. Nintendo Game Boy Advance SP Brightness Switch Replacement, Brightness Switch: шаг 8, изображение 1 из 1
    • With your fingers, lift the track pad out off the brightness switch.
    • Keep the track pad clean. A dirty or dusty track pad will lead to the brightness switch not working when you press it.
  9. Nintendo Game Boy Advance SP Brightness Switch Replacement: шаг 9, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Купить
    • Using tweezers, lift the brightness switch out of the Game Boy Advance SP.
Заключение
15 участников успешно повторили данное руководство.
DJ Pantone
Участник с: 01/11/13
1 924 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 17-22, Forte Winter 2013 Участник Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 членов
Автор 39 руководств
Один комментарий
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 32
За последние 30 дней: 156
За всё время: 18,857
