Nintendo Game Boy Advance SP Power Switch Cover Replacement
Выберете то, что вам нужно
  1. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Battery: шаг 1, изображение 1 из 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Power Switch Cover Replacement: шаг 2, изображение 1 из 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Power Switch Cover Replacement: шаг 3, изображение 1 из 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Back Cover: шаг 4, изображение 1 из 2 Nintendo Game Boy Advance SP Power Switch Cover Replacement, Back Cover: шаг 4, изображение 2 из 2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Power Switch Cover Replacement: шаг 5, изображение 1 из 1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: шаг 6, изображение 1 из 2 Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: шаг 6, изображение 2 из 2
    • Lift the power switch cover away from the left side of the device using your fingers or tweezers.
Заключение
17 участников успешно повторили данное руководство.
DJ Pantone
Участник с: 01/11/13
1 924 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 17-22, Forte Winter 2013 Участник Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 членов
Автор 39 руководств
Один комментарий
This doesn't explain anything about how to replace the switch
Michael - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 26
За последние 30 дней: 154
За всё время: 20,023
