Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows how to properly remove and clean the fan. This will help prevent your GameCube from overheating.
Выберете то, что вам нужно
Turn over the Gamecube so that the bottom side is facing up.
Use the 4.5 mm Gamebit screwdriver to remove all four screws.
With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
Move the GameCube so that the inside is facing upwards.
Using a Phillips #2 screwdriver, remove the two screws (circled in red) attaching the fan assembly to the unit.
Carefully disconnect the fan connector from the socket, as depicted in the second picture.
Once the fan is removed, use compressed air to clean the dust off of the fan blades.
10 участников успешно повторили данное руководство.
