Nintendo GameCube Motherboard Replacement
Выберете то, что вам нужно
  1. Nintendo GameCube Motherboard Replacement, Top Case: шаг 1, изображение 1 из 3 Nintendo GameCube Motherboard Replacement, Top Case: шаг 1, изображение 2 из 3 Nintendo GameCube Motherboard Replacement, Top Case: шаг 1, изображение 3 из 3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Motherboard Replacement: шаг 2, изображение 1 из 3 Nintendo GameCube Motherboard Replacement: шаг 2, изображение 2 из 3 Nintendo GameCube Motherboard Replacement: шаг 2, изображение 3 из 3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
    This can also be done whilst being in the normal upright position after all 4 of the 4.5mm Gamebit screws have been removed. Pull the top of the shell directly upwards and it should slide off easily.
    Less chance of snagging any wires or parts.
    Christopher Cox - Ответить
  3. Nintendo GameCube Motherboard Replacement, Removing the back panel: шаг 3, изображение 1 из 1
    • Gently press down on the clips located on either side of the back panel.
    • Carefully remove the back panel from the GameCube.
    A second picture clearly showing which direction to pull the back panel away from the unit would be nice.
    rubixtriangle - Ответить
  4. Nintendo GameCube Motherboard Replacement: шаг 4, изображение 1 из 1
    • Unclip the controller ports at the front of the unit.
    • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
    • Controller ports are where the controllers plug into the game console, and are a half circular shape.
    well... what happens if accidentally i disconnected it?
    negroporexcelencia - Ответить
    presumably nothing major. The CMOS battery is attached to the controller ports, so the most i'd expect is that the gamecube loses it's date/time setting. As long as you reset that before jumping into animal crossing or something, you should be fine. I'm currently doing a teardown of my gamecube, and if something does prove to have gone wrong, i'll report back.
    sigoshi -
    okay, i finished putting it back together. gamecube works fine and surprisingly still remembers what year it is. boots into smash bros and shows memory card contents fine.
    sigoshi -
  5. Nintendo GameCube Motherboard Replacement, Separate the casing: шаг 5, изображение 1 из 2 Nintendo GameCube Motherboard Replacement, Separate the casing: шаг 5, изображение 2 из 2
    • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
    • Carefully separate the gray outer casing of the control port and the circuit board.
    That step is not needed for the laser replacement.
    Vincent Léon - Ответить
    Love ur labeling and legends. Good on ya
    Josh Johnston - Ответить
  6. Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: шаг 6, изображение 1 из 2 Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: шаг 6, изображение 2 из 2
    • The left side of the unit contains the cooling fan and its housing.
    • Carefully remove the two screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
    Why can't the fan wire be detached?
    Josh Hobbs - Ответить
    It can, but you might not want to
    Jilvenhong Dickinson -
  7. Nintendo GameCube Motherboard Replacement: шаг 7, изображение 1 из 2 Nintendo GameCube Motherboard Replacement: шаг 7, изображение 2 из 2
    • Remove the four Phillips #1 screws retaining the ground springs.
    • Carefully remove the ground springs from the main unit.
  8. Nintendo GameCube Motherboard Replacement: шаг 8, изображение 1 из 2 Nintendo GameCube Motherboard Replacement: шаг 8, изображение 2 из 2
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
    Are these 12 screws the exact same kind like the 2 that were on the fan?
    blaise ventura - Ответить
    Yes! As far as I can tell anyway. Makes sense, too since opposite the fan you have five of the same holes as well.
    Ben Zelinsky - Ответить
  9. Nintendo GameCube Motherboard Replacement, Remove the assembly: шаг 9, изображение 1 из 3 Nintendo GameCube Motherboard Replacement, Remove the assembly: шаг 9, изображение 2 из 3 Nintendo GameCube Motherboard Replacement, Remove the assembly: шаг 9, изображение 3 из 3
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached.
  10. Nintendo GameCube Motherboard Replacement, Motherboard: шаг 10, изображение 1 из 2 Nintendo GameCube Motherboard Replacement, Motherboard: шаг 10, изображение 2 из 2
    • With the Optical Drive Assembly removed, your GameCube should now look like this.
    • Remove the 6 screws (circled in orange) on the heat sink using a #1 Phillips screwdriver.
  11. Nintendo GameCube Motherboard Replacement: шаг 11, изображение 1 из 2 Nintendo GameCube Motherboard Replacement: шаг 11, изображение 2 из 2
    • Gently lift the motherboard from base (as shown in second picture).
  12. Nintendo GameCube Motherboard Replacement: шаг 12, изображение 1 из 2 Nintendo GameCube Motherboard Replacement: шаг 12, изображение 2 из 2
    • Carefully disconnect the ribbon cable connecting the motherboard with the front panel.
    • At this point you can replace the old motherboard with a new one and enjoy your now-functional GameCube!
Заключение
12 участников успешно повторили данное руководство.
mwbisson
Участник с: 11/05/09
1 038 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 6-2, Maness Fall 2009 Участник Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 членов
Автор 45 руководств
3 Комментариев
What happens if you disconnect that cable (localizated on Step 4)?
Santi12008 - Ответить
Its soldered to the front-board and the connector is on the main-board under the disc assembly, trying to remove it will break it.
Joseph Lalone -
I have been having trouble with my cube shorting out when I insert a memory card into slot A. What is the best way to get at it see if this is the case, and what should I be looking for?
Many thanks
farrell dann - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 41
За последние 30 дней: 223
За всё время: 28,775
