Введение
Removing the top case will allow you access to the GameCube's internal parts.
Выберете то, что вам нужно
Turn over the Gamecube so that the bottom side is facing up.
Use the 4.5 mm Gamebit screwdriver to remove all four screws.
With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
Move the GameCube so that the inside is facing upwards.
18 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
