Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Follow this guide to remove the rear panel from a Nintendo Switch.
A single screw is hidden underneath the kickstand.
Выберете то, что вам нужно
Remove the single 3.8 mm Phillips #000 screw from the right Joy-Con rail.
Remove the single 3.8 mm Phillips #000 screw from the left Joy-Con rail.
75 участников успешно повторили данное руководство.
10 Комментариев
Excellent and concise guide.
The new panel doesn’t come with the sticky grille pieces x 2 on the bottom. Is it supposed to be a straight transfer between the old and the new?
You can transfer the grill to the new back plat
Just did this replacement and there are a few things to keep in mind that this review does not mention. There are x2 square foam pieces that can be transferred to the new panel located at the bottom backside of the old. Also, the game cartridge shield hardware and the kickstand holder hardware have to be taken off the back of the old panel and transferred to the new panel. The kickstand has 2 Phillips #000 screws and the game cartridge shield has 1 Phillips #000 screw
Is the casing the same between the HAC model and the HAD model? This guide doesn’t specify
