Введение
This guide will show you the steps on installing the joystick. This will be helpful if the joystick isn't working properly.
Запчасти
No parts specified.
  1. Pull down on the battery cover release lever and pull back to remove the cover. Pull down on the battery cover release lever and pull back to remove the cover.
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Take out each battery then put the covering back on.
    • Take out each battery then put the covering back on.
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Remove the eight 9-mm Tri-Wing screws on the back panel with the Tri-wing Y1 screwdriver. During reassembly, firmly hold the panels of the controller together while replacing screws so the panels don't separate.
    • Remove the eight 9-mm Tri-Wing screws on the back panel with the Tri-wing Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing screws so the panels don't separate.
  5. After each screws has been removed carefully turn over the controller, and place on a flat surface. Slowly separate the top panel from the bottom panel.
    • After each screws has been removed carefully turn over the controller, and place on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off of the motherboard.
    • Once seperarted set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  6. Use tweezers to remove the buttons. It may be easier to remove the A button off of the pad by lifting it with your fingers. During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  7. Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand. Pull off the grey joystick cover.
    • Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand.
    • Pull off the grey joystick cover.
    • During reassembly, make sure the slots inside the joystick cover line up with the motherboard so it can fit back together.
Заключение
6 участников успешно повторили данное руководство.
Garrett Leung
Участник с: 16.04.2013
883 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 членов
Автор 20 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 2
За 7 дней: 12
За 30 дней: 45
За всё время: 5,315
