Введение
Use this guide to remove the heat sink from your Wii's motherboard.
  1. Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii. Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
    • Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
  3. Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Carefully pull the faceplate away from the front of the Wii. Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Open the controller port cover until it is perpendicular to the black controller port bezel. Pull the controller port cover straight up to release it from the outer case. Repeat this procedure for the memory card port cover.
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel. Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Remove the two 5 mm Phillips screws above the controller ports.
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Remove the following screws:
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Wing screw
  12. Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
    • Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
  14. Lift the outer case straight up off the body of the Wii.
    • Lift the outer case straight up off the body of the Wii.
  15. Remove the small Phillips screw securing the battery door to the bottom panel. This screw is captive to the battery door.
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
  16. Remove the 8.2 mm Tri-Wing screw that was hidden beneath the battery door.
    • Remove the 8.2 mm Tri-Wing screw that was hidden beneath the battery door.
  17. Remove the two 8.2 mm Tri-Wing screws securing the DVD drive shield near the controller ports.
    • Remove the two 8.2 mm Tri-Wing screws securing the DVD drive shield near the controller ports.
  18. Lift the DVD drive shield upward and remove it from the Wii.
    • Lift the DVD drive shield upward and remove it from the Wii.
  19. Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
    • Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
  20. Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
  21. Pull the DVD drive power cable away from its socket on the DVD drive.
    • Pull the DVD drive power cable away from its socket on the DVD drive.
  22. Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself.
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
  23. Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
  24. Remove the two 10 mm Phillips screws securing the fan to the fan shroud. Remove the fan from the Wii.
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
    • Remove the fan from the Wii.
  25. Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board. Lift the Wi-Fi antenna out of the fan shroud.
    • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
    • Lift the Wi-Fi antenna out of the fan shroud.
  26. Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
    • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
  27. Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
    • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
  28. Carefully de-route both antennas from the frame of the Wii and lay them aside.
    • Carefully de-route both antennas from the frame of the Wii and lay them aside.
  29. Remove the three 10 mm Phillips screws securing the fan shroud to the Wii. Lift the fan shroud off the heat sink and remove it from the Wii.
    • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
    • Lift the fan shroud off the heat sink and remove it from the Wii.
  30. Remove the following six screws securing the EMI fingers to the bottom panel: Four 7 mm Phillips screws Two 11.3 mm Phillips screws
    • Remove the following six screws securing the EMI fingers to the bottom panel:
    • Four 7 mm Phillips screws
    • Two 11.3 mm Phillips screws
    • Remove both sets of EMI fingers from the Wii.
  31. Remove the following three screws: One 7 mm Phillips screw
    • Remove the following three screws:
    • One 7 mm Phillips screw
    • Two 10 mm Phillips screws
    • Lift the bracket out of the Wii.
  32. Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii. Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild. Remove the bracket from the Wii.
    • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
    • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
    • Remove the bracket from the Wii.
    • Be sure not to lose the small square nut loosely held by the black plastic bracket.
  33. Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
    • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
  34. Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
  35. Remove the four 11.3 mm Phillips screws securing the heat sink to the bottom panel.
    • Remove the four 11.3 mm Phillips screws securing the heat sink to the bottom panel.
  36. Lift the heat sink off the motherboard.
    • Lift the heat sink off the motherboard.
    • When working near the exposed processors, be sure not to disturb the thermal pads if you don't plan to replace them. They are fragile and can tear easily. If you do plan to replace the thermal pads, thermal paste can be used.
Заключение
12 участников успешно повторили данное руководство.
Комментариев: 4
This guide also works great as a thermal paste replacement guide for the Wii, just remove the old thermal pads and clean off the heatsink, CPU, GPU, and WiFi board, and apply Thermal Grease to the CPU, GPU, And WiFi board.
Lucas Hoekstra (Lucas9810) - Ответить
Worked great! Was able to reapply thermal paste on my wii. It’s working great so far!
chris morales - Ответить
Can we use Thermal Paste instead of Thermal Pads?
Manuel E. Carballo Jr. - Ответить
Yes, thermal paste can be used. I strongly recommend Thermal Grizzly Kryonaut, as it’s the second-best-performing non-metallic thermal paste on the market (the only better performer is Kryonaut Extreme).
Ethan Zuo -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 37
За последние 30 дней: 150
За всё время: 16,994
