Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Installing a Wii Remote motherboard requires the removal of the front cover plate and allows access to the B button.
Запчасти
Детали не указаны.
  1. Flip the Wii Remote over so the battery cover faces you. Push up on the bottom tab.
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller. These tabs are breakable. However, if the tabs are broken the controller will still function.
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Using the connector port, gently lift the motherboard about 2 cm from the base. Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
  6. Grasp the edges of the motherboard and pull it straight away from the case. Grasp the edges of the motherboard and pull it straight away from the case.
    • Grasp the edges of the motherboard and pull it straight away from the case.
Заключение
16 участников успешно повторили данное руководство.
Emily
Участник с: 14.04.2013
927 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 3-44, Amido Spring 2013 Участник Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 членов
Автор 12 руководств
Комментариев: 6
Where do you find a motherboard and how much do they typically cost?
Jeff - Ответить
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - Ответить
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign -
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - Ответить
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - Ответить
Just adding a comment to dispute the above suggestion that “this is useless”. I used this guide to help repair a damaged Wii Controller which had had some battery leakage onto the mainboard. I was able to open the controller, clean up (using vinegar and water) the battery corrosion and re-assemble the controller. It works fine again now and I used this guide to find out that there are plastic clips holding the case together.
Sylph Hawkins - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 50
За последние 30 дней: 211
За всё время: 20,975
