Введение
Installing a Wii Remote motherboard requires the removal of the front cover plate and allows access to the B button.
Выберете то, что вам нужно
Flip the Wii Remote over so the battery cover faces you.
Push up on the bottom tab.
Remove the battery cover.
Remove the first battery by pressing down on the positive end and pulling the battery out.
Remove the second battery by pushing up on the positive end and pulling the battery out.
Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
Repeat with the two bottom screws.
With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
Open the front plate like a book.
Mine is not opening like a book? What do I do?
It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
Using the connector port, gently lift the motherboard about 2 cm from the base.
26 участников успешно повторили данное руководство.
7 Комментариев
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Where can i buy a brand new and original (not fake of course) wii remote for $20?
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Just adding a comment to dispute the above suggestion that “this is useless”. I used this guide to help repair a damaged Wii Controller which had had some battery leakage onto the mainboard. I was able to open the controller, clean up (using vinegar and water) the battery corrosion and re-assemble the controller. It works fine again now and I used this guide to find out that there are plastic clips holding the case together.
I can't sync my Wii balance board. and remote at the same time. when the Wii remotes sync the balance board goes out and vice versa
