Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Disconnect all external cords from the Wii console.
Gather all tools.
One small screw holds the BIOS memory battery.
Once that screw is removed, you can slide out the plastic slot.
Remove these three black case screws. The one on the right is a few mm longer. These screws hold on the black plastic cover for the GameCube ports.
Lift off the black plastic plate.
There are four screws: two Phillips #00 and two Tri-Wing.
Remove all screws from the case.
Several case screws require a Tri-Wing screwdriver.
The next step has more pictures of removing rubber feet and the screws underneath. The feet and screwcovers are self-adhesive, but not every foot or screwcover has a screw.
Once all screws are removed, you should be able to pull off the front drive panel.
The wire connecting the front panel (green squares in the third image) can be pulled out gently by hand or with the help of a spudger.
We lifted up the cover of the optical drive by removing the six Phillips #00 screws. These are all labeled on the previous image.
There are a ton of parts in the optical drive, but there is nothing very fancy about this drive compared to other slot-loading drives, so I didn't take it apart completely. There are also a ton of gears and levers that I did not want to deal with.
The screws holding in the drive were deep within the casing.
Once those screws were removed, the entire case could be lifted off.
This wire slid out from its horizontal slot. Once it was detached, the ribbon cable came out as well.
With those wires detached, the optical drive came off completely.
We begin trying to get to the logic board by removing this small black plastic rim.
Remove all screws from the logic board cover. Two are recessed in the middle; others are along the edge. More will become visible as other parts are removed. It's like a game! You can start with the screws holding in the black plastic pieces, but I started with the most visible and went from there.
There are two wires (shown in the third picture) coming from the logic board and connected to the Wi-Fi antennas. These are delicate. Do not break them.
Detach the case fan. There are two screws holding it in.
You must detach the power connector for the fan if you want to remove it completely.
If your screwdriver is not magnetized, you will need a magnet to get out some of the embedded screws. You can hold a magnet against your screwdriver shaft to temporarily magnetize it.
Once all the screws out, you can begin to remove the black casing.
With the black plastic covers off, we can see all the screw holes. Most of the screws are out by now, but once the rest of them are out, you can lift off the logic board cover.
Note that at least one part is thermal padded to the logic board cover. You might have to replace this thermal pad, but I didn't. I just pushed them back together. Oh well!
Remove any remaining screws in the logic board cover.
Once all screws are removed, lift off the logic board cover.
Look around.
This is the thermal padding.
We opted not to remove the heat sink from the logic board, but it certainly could be removed.
We stopped there.
A muffin tin worked really well to organize all the screws.
Putting the Wii back together took only about half an hour, and it works perfectly. We improved Nintendo's design by three or four screws and one square nut, but worsened their design by one piece of duct tape (to hold in the bios battery).
27 Комментариев
I was kinda hoping you would take apart the optical drive assembly, you said there is "nothing fancy" about it, but since Nintendo designed this drive to be able to take the "mini" discs from GameCube, they have to work out a mechanism to center the disc before loading it onto the motor, hence "a ton of gear and levers" and that's the exact thing I actually wanted to see, I really wanted to know how they made it work..
:P
Maybe I can make a guide for you with it like that. I plan to replace the Hard Drive in my wii so ill make a guide.
@zeldaawesome It is not a hard drive, it is NAND. In fact, that’s about as far away from a hard drive as you can get.
Xu Xian -
I have a dud drive, so i might just do this.
Nice guide. I have one suggestion and one comment to add.
Suggestion: a different color circle in the pictures for the Tri tip screws would speed up re-installation.
Comment: the extra square nut holds in the BIOS battery cover which is quite inconvenient to discover as it is the last screw you reinstall.
