Введение
Use this replacement guide for step-by-step instruction on how to replace the power and accompanying buttons on the Wii U console's front face panel.
Выберете то, что вам нужно
You will first need to find all the screws hidden underneath the black (or white) square stickers. They are all located on the bottom side of the Wii U.
Remove the CMOS battery door on the left side of the console.
Once the door is removed, remove the three Phillips #0 screws.
Rotate the device so that the front plate is facing you.
Remove the two Phillips #1 screws.
Once unscrewed, remove the black braces that hold the power button, eject button, and sync button in place.
