Введение
We pick up where we left off after removing the joysticks. To reach the D-Pad, we will first remove the motherboard.
Выберете то, что вам нужно
Turn the controller over to reveal the battery cover.
Use the J000 screwdriver to remove the screw that secures the battery cover.
Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
Use the spudger as a lever to pry up and remove the battery from the compartment.
Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
Locate the two 4 mm motherboard screws, shown circled in red, with the J0 screwdriver.
Remove the motherboard and connected components. The rubber pad of the D-Pad is indicated in the image by the red arrow.
Remove the rubber pad and D-Pad button. The D-Pad can be replaced by the new D-Pad or be cleaned to improve condition.
3 участников успешно повторили данное руководство.
