Nintendo Wii U Pro Controller ZL and ZR Button Replacement
Выберете то, что вам нужно
  1. Nintendo Wii U Pro Controller ZL and ZR Button Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: шаг 2, изображение 1 из 2 Nintendo Wii U Pro Controller ZL and ZR Button Replacement: шаг 2, изображение 2 из 2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller ZL and ZR Button Replacement, ZL and ZR Buttons: шаг 3, изображение 1 из 1
    • Once the battery has been removed, we will remove the 4 screws in the battery compartment and then the 4 screws around the back of the case. These 8 screws use the Y0 bit. Each of these screws are 5.5 mm.
    • The four screws on the outside are extremely deep into the casing, and the holes are pretty small. You will need to use a 4 mm driver bit extension to reach these screws.
  4. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: шаг 4, изображение 1 из 1
    • Once all of the screws are removed, simply use one hand to hold the front panel in place and lift up on the back panel to remove it. Place the back panel so the insides are facing up towards you.
  5. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: шаг 5, изображение 1 из 2 Nintendo Wii U Pro Controller ZL and ZR Button Replacement: шаг 5, изображение 2 из 2
    • Locate the two triggers (ZL and ZR) and pop them up and out by pressing on them from the outside.
Заключение
Еще один человек закончил это руководство.
Jesse Burton
Участник с: 09/17/15
604 Репутация
Автор 3 руководств
Команда
IUPUI, Team 2-2, Harley Fall 2015 Участник IUPUI, Team 2-2, Harley Fall 2015
IUPUI-HARLEY-F15S2G2
4 членов
Автор 15 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 19
За всё время: 5,281
