Введение
Sometimes, your tire's inner tube just goes flat. To fix that, you either buy a new one or patch the faulty one. Either way, you'll have to get the tube out of the tire, and this guide shows you how.
Выберете то, что вам нужно
Use a wrench to loosen the nut holding the wheel's axle on one side.
Once it's loose enough, continue removing the nut with your hand.
Unscrew the cap from the air valve.
Release the tire's air by pressing a thin object on the center pin of the valve.
Wedge a tire lever between the tire and the rim. Grab the tire with the lever's inward scoop.
Grab the tire's edge with the lever and pull it back to scoop the tire from the rim.
Keep the tire lever anchored on a spoke with the notch on the lever's opposite end.
Repeat with a third tire lever farther around the tire.
Alternate lifting the second and third levers until the tire comes partway off.
Wedge the tire off of the other rim with the tire levers.
Pull the air valve from its hole in the rim to completely remove the tire.
Now that the tire and tube are off of the rim, gently pull the tube out of the tire.
Now, you've separated your tube, tire and rim.
Remember to inflate just a little bit of air into the tube before you try to install it, as that makes the process go much smoother.
