Введение
The Niu Kqi3 Max scooter is a popular electric scooter that is both fast and environmentally friendly. However, like any mode of transportation, its tires can wear out and need replacement over time. In this guide, I will provide you with step-by-step instructions on how to replace the tire on a Niu Kqi3 Max scooter. Whether you are a professional mechanic or a DIY enthusiast, this guide will help you get your scooter back on the road in no time.
Выберете то, что вам нужно
Use a floor jack or center stand to lift the scooter, making it easier to remove the tire.
Remove the sticker that covers the the Mortorq drive screw under it.
Use the pliers to remove the cotter pin and loosen the nut securing the rear wheel to the axle.
Use the tire lever to pry the tire off the rim of the wheel.
Remove the inner tube from the tire and rim.
Detach the connectors so you're able to completely remove the tire.
Insert the new inner tube into the tire and align it with the rim. Use the tire lever to carefully fit the tire back onto the rim of the wheel.
Reattach the nut and secure it with the cotter pin. Slide the rear wheel back into the scooter frame and reattach the axle bolt.
Replacing a tire on a Niu Kqi3 Max scooter is not a difficult task, but it does require a few tools and some basic mechanical skills. With the help of this guide, you can successfully replace the tire on your scooter and get it back on the road quickly and safely.
