Введение
To access the grinder, the machine must be opened. Then the grinder can be removed completely or only the grinding stones can be replaced. The grinder is the same as in many devices from Siemens, Melitta, Jura, Bosch, etc. installed.
Выберете то, что вам нужно
Remove all attachments such as water reservoir, coffee compartment lid, trestle drawer. Remove all coffee beans in the storage container.
Unscrew the five Torx T10 screws on the back.
Unscrew the two Torx T10 screws on the front edge of the heat plate.
Lift the front edge of the heat plate and slide it forward a bit to clear the tabs on the back edge.
Put the heat plate back down, but in such a way that you can reach the screws underneath.
Unscrew the two Torx T10 screws located under the heat plate.
Gently lift the upper side a bit and put it back down.
Push the side panel on the water tank back about 2 cm.
Place the side panel next to the machine. Do not remove it completely yet, the cables of the switch are still connected.
Disconnect the flat plugs from the switch. Be sure to note the order of the cables for later reassembly.
Remove the side panel.
Lift the top side slightly.
Press down the locking tab on the plug of the white sensor cable and pull off the black plug towards the front of the machine.
Press the two catches of the counterpart on the sides together and slide it out of the opening towards the back.
Now the top is free and you can remove it.
The grinder is damped with foam mats. One mat just rests on top. Remove it.
The grinder is open in front of you.
Work through the steps in reverse order to reassemble your device.
Особая благодарность этим переводчикам:
100%
shingleпомогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
