Введение
Are your batteries dead? With this guide, you will know learn how to easily replace the batteries in your Nokero Shavano N220.
Инструменты
Запчасти
Детали не указаны.
Use one hand to hold the device still and the other to remove the lid by turning it clockwise using your index finger and thumb.
Using your index finger and thumb, squeeze the top and bottom of the plastic bezel together, and lift it off of the device.
Insert a spudger into the slot at the bottom of the lower battery cover, and pry the cover up.
Repeat for the second battery cover.
Now take your new batteries or let the old ones charge and reinsert them.
Follow the picture of the battery on the inside of the device.
Once you have put in both sides, insert the covers.
Match the ends and it should just pop into place.
Almost there, now take the white piece that you set aside and squeeze one side once again using your pointer finger and thumb to put it in.
Take the lid and turn it counter clockwise using your index finger and thumb.
Еще один человек закончил это руководство.
