Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
To replace the motherboard, phone disassembly is required.
Выберете то, что вам нужно
Press down on the small gray button located on the back of the phone.
Slide the back plate down and off.
To remove the battery, begin by holding the phone sideways.
Then, insert your thumb in the groove below the battery and push the battery up and out.
Locate the spudger. A photo of the correct spudger is provided to the left.
Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
Insert the spudger into each square hole and push up to detach the face plate.
Note: The keypad will be loose and may fall off during this step.
Pull the face plate up and off of the phone.
To remove the keypad, simply lift it off the phone.
Locate the 6 screws on the metallic sheet that previously held the keypad. (This sheet, shown in the pictures, is the top side of the motherboard).
Warning: The middle two screws are attached to the base of the phone with two black plastic rings. Use tweezers to remove the screws carefully to avoid breaking the plastic rings
Use a size T6 Torx screwdriver to remove each of these 6 screws.
